pcoplin's avatar
pcoplin
Explorer II
Nov 27, 2015
Atwood furnace blowing cold some time at night...
I have an Atwood 7900 series furnace in my 2001 Lance 915. DSI iginition, no external timer relay.
The past couple nights I have woke up to cold to find the heat has shut off and it just blows cold. Turning the t-stat off then back on will get it blowing warm again. Both times it was below freezing. I've never used it below freezing until now.
The other night was on battery power, but last night was plugged in to shore power. Getting good power to the relay. Fridge was working fine on propane the night before, on shore power this time. Good propane flow to the stove.
I've googled all over today learning about it and have learned a bunch, but haven't nailed mine down yet.
Problem is I can't get it to replicate this morning, even though it was high 20s, although it's now warming up to above freezing. So I can't figure out of it's not relighting, or not shutting the blower off after cycling.
ONly thing I can think of it is propane oil trapped? Or is there another function (sail valve or overheat) that will fail during the night?
Thanks for any input.
