enblethen
Aug 17, 2015Nomad
Check the grounds on the gas valve. It is located behind the valve on a mounting bolt for the valve.
Split the wiring on the gas valve. Use an ohm meter to check the two coils. They should have the same resistance.
Clean the contact on the circuit board.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
