Old-Biscuit
Jun 18, 2017Explorer III
Atwood HE Model is not any different then a Norcold Or Dometic except that it uses HELIUM Gas vs HYDROGEN Gas
It does have a built in 'Tilt Monitoring' and the 'CHECK' fault light indicates more then just an issue with propane not lighting.
Below ae ERROR Messages for that HE Model
ERROR MESSAGES --------INDICATOR--------------DESCRIPTION
CHECK light
Slow beep------------Door Not Closed----------Close Door
Once every 2 sec
CHECK light
Very Slow beep-------Back Up Operating MODE---Replace Thermistor
Once every 10 sec----Thermistor damaged
Temp Set LEDs
all flash when-------Back Up Operating MODE---Replace Thermistor
switch is pressed----Thermistor damaged
CHECK light
GAS light on--------Burner failed to light----Retry
CHECK light
GAS light flashing---Gas unavailable----------Gas ON
CHECK light
AC light flashing----AC unavailable-----------AC On
CHECK light
AUTO light-----------1. Open DC fuse---------Replace Fuse
AC light-------------2. Open thermal switch--Cooling Unit Tripped
ALL On---------------3. Prolonged operation in severe tilt position
Here is a more in-depth troubleshooting guide
https://www.manualslib.com/manual/1067876/Atwood-He-0601.html#manual
Check the 'diagnostic' mode
CHECK light
Once every 2 sec
CHECK light
Temp Set LEDs
CHECK light
CHECK light
CHECK light
CHECK light
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
