Old-Biscuit
Jun 09, 2015Explorer III
fullhouse10 wrote:
Oh Sorry, i will clarify my conversation with atwood, the trailer is in canada at the moment so I have to pay for diagnostic report from dealer if they find that it is a warranty issue, i have to submit the quote and diagnostic bill to them for coverage and reimbursement
Installation, proper clearances, dead air spaces, bad circuit board, bad burner assembly etc etc......would ALL be warranty issues
Hard to think of a non warranty issue with a 2015 model
Unless you sprayed water in thru vents :B
And remember......having helium doesn't change anything (how it works).
It is just an absorption fridge.....rv tech should have no problem with diagnosis......same electric/propane heating, cooling unit, vapor flow as Dometic/Norcold using hydrogen gas.
HERE is Installation/Service Manual with clearances/installation requirements just in case RV tech is unsure :B
Good luck!
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
