tesc213's avatar
tesc213
Atwood Helium Fridge problem
I have a 2012 Attwood Helium Fridge. Up until this weekend it's been working fine. The week I started getting a check gas message. I have lots of propane. The fridge tries to light but won't maintain. The flame looks good through the access hole but shuts down after 30 seconds. After a few tries at restarting it will work for a couple of hours but starts all over again. Is there a flame sensor or something that's acting up? It's way back in the bush so taking it in to a dealer is not an option.
  • So what is the downside trade-off to using helium instead of hydrogen??
    (There has to be ... or they wouldn't have been using hydrogen all these years.)
  • Bill.Satellite wrote:
    Old-Biscuit wrote:
    pnichols wrote:
    I'm curious ... what is "helium" refrigerator technology?
    Helium replaces the Hydrogen in the absorption fridge.
    Hydrogen? BOOM! I think you meant ammonia.
    Nope, there is hydrogen in most of the RV refrigerators out there. It is used as part of the phase liquid/gas change process of the ammonia.
    that is what catches fire from leaks. The helium is now being used instead of hydrogen because it won't burn.
  • The flame sensor is the spark electrode- it sends a small current through the flame to the burner. The gap should be 3/16" between electrode and burner, burner needs to be clean.
    They do use Helium in place of Hydrogen- I have trouble finding the partial pressure of Helium, which is the "magic property" of those gasses.
  • I can't find where the flame sensor is. There is a temperature sensor(I think) above the fame but it's outside the flue. Where is the flame sensor located? It doesn't show on the wiring diagram.
  • Do the "annual", yes annual burner area tune-up. No special tools and not parts needed.
    Lots of little things are addressed than can cause it to not work properly on propane.
    Same with any absorption refrigerator.
  • Yes, there's a flame sensor. Make sure it's positioned properly in the flame and clean it with a BRASS brush or some carburetor cleaner which will dissolve the carbon.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
