fourthclassC wrote:
Howdy, How every one is holding up with the current situation.
My how water is too hot. Thinking about getting the adjustable disc thermostat from Atwood. I've seen them for 35 to 50 dollars. Saw some folks added thermo conductive compound where the "disk" contacts the tank . Has any one used these to lower the water temp? Interested in all and any comments. Thank You
Hi,
I'll offer something not said yet.
There is the possibility your heater may be overheating the water due to hard water scale buildup inside the heater. A quick way to know for sure what your water temperature is, is to actually measure the water temp. Do not assume the heater is working to factory spec.
At the bath or kitchen sink, whichever is closer to the water heater would be better, run the hot water only enough that is it very hot and check the temperature with a thermometer you know is accurate. Cooking thermometers will work as they go high enough in temperature. They can be checked by testing when water on the stove boils, which is 212F unless you are very high above sea level.
If you find the water is a lot hotter than 140F, it may be the scale build up in the heater. A buildup of scale over the years can slow down the rate at which the water temperature gets to the sensor on the outside of the tank and make the water hotter.
If your profile is up to date, your water heater is from 2003. And if your water heater tank is still original, that is a good many years of potential scale build up unless you have a portable water softener. Which many or most do not.
Atwood has a procedure on doing a vinegar boil out of the heater to help reduce the scale. I have done this boil out on 3 different water heaters since I learned of it a year ago, and every one of those heater now warms up and shuts down faster then the owners can ever recall.
Point being, do some troubleshooting first to see what the problem may be. Installing an adjustable T stat or a water mixing valve may not be the right fix.
Hope this helps
John
