dpgllg's avatar
dpgllg
Atwood Hot water heater drain plug
Hello,
My 5th wheel has an Atwood hot water heater that came with a nylon (plastic) drain plug. The location of the plug makes it very difficult to get a wrench or anything on it to remove the plug.
Original Atwood plug
I replaced it with a Camco brass drain plug with a valve that you can open to drain the tank.
Camco plug
The Camco plug was a complete waste of time and money. It leaked constantly and when you wanted to drain it came out so slow that it would take a day to drain the tank. I even popped the pressure relief and opened all my faucets with minimal improvement. Removing this drain plug took over an hour due to location and the brass stripped very easily.
Does anyone have a better solution? What do you use? Any special wrenches that fit better?
Thanks for your response!
Dave
