werni9's avatar
werni9
Atwood HWH
I believe I am in need of replacing the upper check valve because of trickle hot water from faucets. I have a 2000 Winn. Ultimate Advantage and I am trying to get at the back of the WH. Compartment to left is very cramped with water pump and plumbing. Don't see any obvious openings to access the rear to change out valve. ANY PICTURES?? Any ideas how to see back there and if there is room to remove and replace check valve on top? Have a Winterizing pump and it's off, but would like to keep unit ready if needed to winterize. Replace and not just remove valve. Like to do this without pulling the WH.
Lastly, no matter what I do I cannot maintain 20 lbs in my accumulator tank which it calls for. I check top with a regular tire gauge. Drain some water out and 0 pressure. Normal operation and I am at 35-40 lbs. Calls for no more than 20.
2 part question......Hope you can help. It's the weekend and 3 days now no hot water.
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
