dougrainer
Jan 07, 2018Nomad
OK, the system brain has been scrambled by the failure of that 1 jack. So, you have to do a complete reset of all the jacks. It takes TIME and you cannot skip any step in the procedure. If you do, you will fail to reset the system. Especially when it states to CONNECT to your truck. YOU MUST CONNECT TO YOUR TRUCK AS STATED. You cannot just lift the 5th wheel up. If you do not have the operators manual here is the link. Average time for a novice is about 2 hours to do the procedure. About 1 hour for someone skilled at it. Doug
Having RV issues? Connect with others who have been in your shoes.24,247 PostsLatest Activity: May 14, 2025
