C_Schomer
Apr 15, 2023Explorer
I’ve used plenty of adjustable, regulators and set them to the pressure required. There are some really tiny regulators, even meant for pilot lights. You can usually find a manufacturers BTU rating on regulators
There is also a little bit of oil in propane from the industrial pumping equipment, and it can precipitate out into the end users systems. I’ve had to take sensitive equipment apart and clean out that oil.
I have several water column gauges but I used Fluke bench equipment to check the calibration and I’ve had to write a correction chart on each one of them. So just use a water column because that is the gold standard… W.C.
Always make sure you have a quick way to turn off the gas when working on gas appliances, accidents can happen! Craig
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
