dougrainer
Jul 08, 2017Nomad
You HAVE to be an engineer. ONLY they have the time to waste on using equipment that is useless for this problem. Listen to Old Biscuit. You have a BAD Ignition module. The system is EXTREMELY simple. It gets 12 volts plus and then sends the 12 volt signal to the Gas valve for 8 seconds and has the Piezo tower spark for 8 seconds. IF the 12 volts to the gas valve lasts only for 800 milliseconds, the module is defective. BTW, it takes NO tools to figure this out other that a voltmeter or a 12 volt test light. I do it with NO tools, just listen to the Gas valve click or put my hand on it to feel if the valve clicks off. Have you bypassed the ECO tstat? The power to the gas valve goes thru it. Doug
