robrv3
Jul 17, 2017Explorer
problem resolved I cleaned and gapped the igniter the gap was about 3/32 set the gap to 1/8, The module now waits 7 seconds before it stops and indicates an error to test this I had to turn off the gas then turn on the heater. I not sure why doing this the module gives more time for ignition and why it fired up 100% of the time when I turned the water heater power on and off but wouldn't run overnight before I cleaned and gapped the igniter. Top signal is error light bottom signal is gas solenoid power
