dougrainer
Sep 01, 2017Nomad
joebedford wrote:
I just went out to the RV and checked the thermocouple. I clipped my DVM set to DC volts to the end that I removed from the gas control valve. Reading went to zero. There was no change when heat was applied to the thermocouple.
Your first post stated that the pilot stayed ON. It only went out when you tried to engage the Oven burner. Correct? It can take up to 30 seconds for the Thermocoupler to react to the heat. Also, it is VERY sensitive. That is why it is critical that the pilot flame be located correctly and be blue and not yellow. Doug
