jlbias27
Dec 07, 2017Explorer
I have an Atwood hydro flame furnace, 8535, and my fuses just started blowing on the breaker panel inside. Thought it might be the motor so I just replaced it. Even tried a new thermostat. I bypassed the fuses by putting in a piece of wire instead of the fuse and the circuit breaker on the motor tripped and continues to trip. I took my meter and did a continuity test at the panel in the trailer and found continuity between the negative and the load side of the fuse holder. I have a dead short somewhere. Will run a continuity test via the wiring diagram in the morning. The blower kicked on the moment I jumpered it across for around 5-10 seconds. The burner wanted to kick on and will still and try but without the blower, it won’t. Suggestions??
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
