beemerphile1
Dec 08, 2017Explorer
jlbias27 wrote:
I have an Atwood hydro flame furnace, 8535, and my fuses just started blowing on the breaker panel inside. Thought it might be the motor so I just replaced it. Even tried a new thermostat. I bypassed the fuses by putting in a piece of wire instead of the fuse and the circuit breaker on the motor tripped and continues to trip. I took my meter and did a continuity test at the panel in the trailer and found continuity between the negative and the load side of the fuse holder. I have a dead short somewhere. Will run a continuity test via the wiring diagram in the morning. The blower kicked on the moment I jumpered it across for around 5-10 seconds. The burner wanted to kick on and will still and try but without the blower, it won’t. Suggestions??
You would be better off starting your own thread rather than posting in a four year old thread. Many people won't realize it is an old thread and respond to the original poster.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
