dougrainer
Jun 18, 2014Nomad
There is a black plastic shim tube that "holds" the burner to the valve/orifice. IF you have grease and such and it flashes back a little, that plastic shim then melts and blocks off gas/air to the burner and then causes a flash fire flame. Usually this is what happens. Rare, but it does happen. Doug
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
