Old-Biscuit
Jun 10, 2016Explorer III
kmb1966 wrote:
Update: I just got mine to ignite, but I am still not sure what is wrong. I got it to ignite by touching the brown wire that connects from Tstat (has a thermal fuse looking thingy on the brown wire), When I held it, I could her something "click" slightly. Holding the wire steady after hearing the slight click sound for about 3 seconds, the igniter fired, and the water heater is now heating on gas. Letting it run for now. must be some sort of bad connection or goofy thermal fuse problem?
Bad terminal connections.....clean and tighten them
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
