SJ-Chris
Mar 09, 2018Explorer II
Atwood water heater ignition acting strange...
I've got a 2006 Four Winds 31P with an Atwood water heater. I was out camping the other day for 2 nights. We had hot water on the first and second days. On the final morning of our trip the hot water heater would not start.
A few details...
- Yes, we had plenty of propane (the furnace was working fine).
- We were not at a high elevation (in case that matters)
- It was ~28 degrees F overnight
It is important to point out HOW it was failing, as I found that to be a bit strange. The normal operation in my rig when turning on the water heater is that I would toggle the switch on the control panel after making sure the propane tank valve is open. A RED light on the switch will turn on. A few seconds later I will hear the click-click-click of the ignitor, and then I would hear the whoosh of the gas igniting, and then the red light turns off.
What was strange on this cold morning is that when I toggled the water heater switch on the control panel the RED light never came on and there was no click-click-click. Therefore, the water heater did not ignite. I tried several times and nothing happened. So we didn't have hot water for the last day.
A day after I got home, I went to try it again and it functioned exactly how it is supposed to function. Toggle switch, red light comes on, click-click-click, ignites, then the red light turns off.
Has anyone seen a water heater behave like this? Any suggestions on how to fix it so that it doesn't happen again? I had a mechanic tell me that I should try changing the igniter and the toggle switch as those are possibly the problem.
Thoughts? Thanks in advance!!
-Chris
A few details...
-Chris
