rekoj71
Apr 04, 2016Explorer
I've had this happen but usually when the site was not level side to side one of the rear jacks might not feel the need to touch. I usually just switched to manual to force the jack to extend. I also had this happen when I was on a site that was way out of level front to back in that the front jacks had used up too much of the fluid to have enough to put down the last jack. Usually I lift a tire when this happens so out come the blocks, of which I will put under both the tires and the jacks so that the tire isn't in the air and the jacks have more fluid to work with.
Doug's copy of the manual is what mine says also.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
