pianotuna's avatar
pianotuna
Nomad III
Aug 14, 2016
autoformers for dummies (me)
Hi all,
I've heard folks saying autoformers "steal" power from the campground and hence from other campers. Here is my understanding of what happens.
The total wattage remains the same less about 4% overhead for running the autoformer.
The volts come by swapping amps for volts.
i.e.
Input to autoformer (not including 4% overhead)
100 volts X 12 amps = 1200 watts
Output from the autoformer
120 volts x 10 amps = 1200 watts
I won't run my roof air on low voltage. I chose 1200 watts as an example because that is about where my roof air starts out at. It is also the maximum number of amps for a continuous demand on a 15 amp circuit.
More usually, in real life, I'll be boosting from just below 110 volts to 120 volts, so the "true" numbers would be
Output to RV 118 volts X 10.17 amps =~ 1200 watts
Input required to the autoformer 108 volts X 11.11 amps X 1.04 (overhead on autoformer) = 11.55 amps or ~1248 watts.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
