TechWriter wrote:
1L243 wrote:
I don't have an onboard Generator.
I will be transferring between shore power and the Inverter.
I assume the output of your transfer switch will go into your 30A electrical panel, right?
If so, that means when you switch over to your 2000W inverter, it will be powering ALL the circuits, including your AC & water heater.
I hope you have a large battery bank.
He doesn't have to turn the AC on. He can set water heater (and refrigerator) to propane. He has already said he will turn off the breaker to the converter/charger. What he is doing is imminently feasible.
