slow96z's avatar
slow96z
Aux Battery Switch Trouble
Hi all:
I have a new to me 2005 Damon Challenger (Ford chassis, gas class A)that has an issue with the aux battery circuit. When I push the momentary switch on the dash I would expect the voltage between the chassis battery (running, showing 14.4v) and the house battery to equalize, but what is happening is the house battery voltage (12.50) starts top climb very slowly, as if it were connected to a charger instead of being parallel connected to a higher voltage source.
There are 2 solenoids under the hood, one black and one silver. I believe that the black one is the house battery disconnect solenoid and the silver is the aux battery connection solenoid. The fuse on top of the black one is good and I don't think that would matter anyway. I found a 7.5 amp fuse in the fuse panel next to the solenoids blown, but replacing it did not resolve the issue. There is a 30 amp fuse that connects to a brown wire that I believe feeds the panel, and that fuse is good with 12v to the circuit.
There is a green/red wire in the same terminal as the brown wire and it has a butt connector on it but it doesn't look like it has ever been crimped to anything so I'm thinking it's for a circuit I don't have.
Does anybody have any ideas why I would only get a trickle of voltage across the solenoid when the button is engaged? And is this green/red wire supposed to be connected to something?
There seem to be a few electrical gremlins in this coach, but this one is the one I'm most concerned about since it left me unable to run my generator yesterday due to a dead house battery from leaving the water pump on while away...
Thanks in advance!
Justin
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
