Alta Volunteer wrote:
Does it have an inverter already?...
I assume that should read "converter" not "inverter". An inverter generates 120v alternating current from your 12v direct current power source.
My camper came with a converter, but no battery charger. A previous owner had added a domestic battery charger so the battery would charge when plugged into shore power, but he bought a really cheap one that just boiled the batteries dry. You need a decent battery charger whether your converter includes that or you buy it separately - e.g. one of these multi-stage intelligent ones that looks after your battery. Otherwise you would be replacing your battery every year like I was, and that gets expensive.
Also, my converter did already connect to the battery, but not to charge it. It had a connection so you could switch between running the camper 12v electrics off battery or converter, but there was no option for connecting the two, so be careful that even if your converter has battery connections that doesn't automatically mean it will charge your battery.
Steve.
