wa8yxm
Sep 08, 2018Explorer III
daiwapr150 wrote:
Can I bypass the aux disconnect solenoid to see if it is faulty? If I can do I bolt the battery cables together and tape them?
Easier than that. Remove both nuts, Remove one cable (the non-battery one) and replace that nut and snug it down so it does not get lost.
Put that cable on the other stud (With the battery cable) and apply nut and snug it down. Use the solenoid as a terminal block to moin both wires
If the studs are long enough you can use method two
Remove one wire, transfer to other stud and add the nut you removed
Finally.. If you have an INtelletec Battery Control System
Jumper using heavy ga wire (liek 4ga) Generator to AUX.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
