D_E_Bishop
Sep 08, 2018Explorer
Got a meter or a test light? Disconnect the load side, connect your meter or test lamp from the load terminal to ground, push the AUX switch, there should be a click as the solenoid pulls in and the meter should show battery voltage or the light will come on.
That does not tell you if the contacts are capable of conducting full amperage but it will show if the solenoid is working or not.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
