debraindi
Aug 31, 2015Explorer
I installed RDS 50 gal tank with small tool box for LML diesel. I removed the filler neck and brazed 3/8 brass elbow. I used a ball valve then a 74 GPH transfer pump wired and loomed up to a relay switch then to a long toggle switch under the dash wired directly to a 20 amp fuse to the battery. There are gravity kits out there but I read about it over filling the tank in some cases .
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
