joe0508ExplorerOct 08, 2016aux fuel tankI have one of those champion 2000 inverter generators and i wont to install an aux fuel tank to it.I found one at walmart but i dont know what fitting i need for the tank to start running the hose.Doe...Show More
GordonThreeExplorerOct 08, 2016Extended run or transfer tank?Transfer uses electric pump.Extended run uses a impulse pump (vacuum) Check out the Yamaha ext run kit, parts are likely the same for your genny.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 11, 2026
Related Contentdeezee aux fuel tankAux. Fuel TankAluminum or Plastic aux fuel tankAux Fuel tank for Ford F25006 chevy aux fuel tank
