C_B_
Sep 06, 2017Explorer II
oldtrojan66 wrote:
Cannot find any positive results from search for this question.
How much voltage should be coming from the truck (when running) to the aux power "in" at the plug in?
I have a 2007 JAYCO 36 RLTS and a 2006 F350 dually. I believe the plug is factory and the pins are wired correctly. From 1 o'clock position to 7 o'clock position I read 11.67 VDC with truck running.
Seems that's not enough to provide even a trickle charge going down the road. Any thoughts?
Thanks in advance, david
You should get 13.6 volts w/truck running. Test the voltage at the power point right of heater controls. Just checked my 2004 F350 and got 13.6.
good luck
C.B.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
