time2roll
Sep 06, 2017Nomad
First verify you are checking the correct pin and ground of the truck connector.
Voltage s/b same as truck battery voltage with vehicle running.
I assume the trailer is not connected when you are checking voltage. Trailer could cause voltage to sag if the load is high.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
