beemerphile1
Sep 06, 2017Explorer
oldtrojan66 wrote:
Cannot find any positive results from search for this question.
How much voltage should be coming from the truck (when running) to the aux power "in" at the plug in?
I have a 2007 JAYCO 36 RLTS and a 2006 F350 dually. I believe the plug is factory and the pins are wired correctly. From 1 o'clock position to 7 o'clock position I read 11.67 VDC with truck running.
Seems that's not enough to provide even a trickle charge going down the road. Any thoughts?
Thanks in advance, david
The voltage at the seven way typically is only slightly less than at the TV battery. Example; 13.6 at battery and 13.4 at seven way.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
