esfd243's avatar
esfd243
Awkward Heat - A/C issue
So we live in NY and are headed to FW in 12 days so of course we need to get the RV open. I checked everything and all is well except for the A/C.
We use a digital Dometic 3 step thermostat. "Fan" runs air just through the A/C. "Cool" runs the A/C. But when I turn on "Heat", the furnace and the A/C come on now. This has never happened before and we used the furnace several times last fall.
Any ideas? I dont know where to start. Maybe replace the thermostat?
  • If he does a RESET, he will still have the same problem. As other posters have told him, PUT the Fan in AUTO. That is what is in the owners manual for this tstat model. Doug
    Is that the square single zone thermostat?
    Reset:
    A system initialization will need to be performed by the installer
    after the system is installed.
    • Make sure the Single Zone LCD thermostat is in the Off condition.
    • Press the “+” button and, while holding it, also press and hold
    the On/Off Mode button for three seconds. LCD will show - - . Press the On/Off Mode button again to turn system off.
    This completes the initialization.
    Dometic themostat manual
  • wnjj's avatar
    wnjj
    Explorer II
    2oldman wrote:
    Where is FW?
    Or Florida if it's Fort Wilderness.
  • Set the fan to auto, then set to heat.
    Jerry
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
