Acampingwewillg's avatar
Acampingwewillg
Explorer II
May 26, 2017
Awning Roller Tube
Since I'm on a "roll", another victim on my Lake Tahoe trip was my awning tube.... It was only suppose to snow for an hour, 8 hours later, my awning was covered in about 6" of snow(yep, I know, should have never had it out, that's another story.) It took me about 2 hours to get all the snow off and of course, it now has a slight bow in the tube. It's still operational but a tad difficult to deploy because of the bow. Any thoughts as to bending it back...I have a thought of setting a couple of 2x4's in the center and trying to pull down on both ends to get a somewhat straighter tube?
  • Just wanted to come back and say we did give the Zip Dee instruction's a try with a few modifications. All in all it worked pretty good, we were able to take some bowing out of it but I think we will do just a bit more next time my brother is up here. Thanks to all!
  • Ahh Yes, it is aluminum (Zip Dee) and I did figure on using a section of 2x4 to prevent that one big tweek in the middle. Thank You for all the suggestions.
  • Ivylog's avatar
    Ivylog
    Explorer III
    If your awning tube is alum you can straighten it fairly easily. If it's steel then it can be done but it's hard not to get a kink in it. Yes you can do it with two big guys and a 2x4 but you need a 2-3' one to put on top of the 2x4 to keep from bending in one spot.
  • Guess I got lucky. A couple weeks ago we woke to several inches of very heavy snow on the awning. It was seriously sagging but no permanent bends. I agree with propping it up in the middle and adding weight to the ends. Good luck!
  • DutchmenSport wrote:
    Extend it again, but stop just short, so the tube is bowed up. Let it snow another 6 inches. See if that helps? :h
    Not a bad idea....maybe I'll just go up to Tahoe next year and wait for it to snow!! LoL
  • Extend it again, but stop just short, so the tube is bowed up. Let it snow another 6 inches. See if that helps? :h
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
