I am replacing fabric on my a&e power awning. I accidentally let spring loose. Do I need to tension it before I put ne fabric on and roll it out? Does it tension its self when rolling out under pow...
Yes, it makes a difference. NO awning torsion spring will self wind. You must put the specific amount of turns per length and type awning. BE VERY CAREFULL. If the end or awning slips loose when you are turning it you will get bruised knuckles or torn skin. BOTH are painful. Remember, standing from the rear facing forward the spring is wound clockwise. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
