Manual awning. Standard 18' Sunchaser. Today, the strap that one uses to deploy the awning and slow detraction decided it had done its duty and separated from the traveler that is INSIDE the roller ...
Drill a 5/16" hole at an angle into the groove near an end cap. Use a screwdriver to slide the old traveler down to the hole and slide it out. The replacement strap's traveler slides in the same way. Another option is to drill a 5/16" hole in the end cap in line with the groove, and then slot the rim of the cap to open up the grove.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
