Manual awning. Standard 18' Sunchaser. Today, the strap that one uses to deploy the awning and slow detraction decided it had done its duty and separated from the traveler that is INSIDE the roller ...
FYI there is NO spring tension on the roller cap the spring tension is on the awning arm cap the roller cap is free and only held in place to keep things together the rivets in the roller can be drilled the cap spun to line up the hole and a couple of sheet metal screws or new pop rivets used to secure the roller cap after you change the strap i have done this several times its a 5 min job
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
