westend
Jul 06, 2014Explorer
Butyl putty tape is usually a good bedding material as it tends to seal around any screws. When I mounted the rails for my solar panel, I used Geocel Tripolymer sealant as a bedding compound and around the aluminum piece that contacted the roof.
Probably the best material would be Eternabond Double Stick tape as the screws will seal themselves when run through the tape.
Eternabond video of screw sealing
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
