crcr
Apr 26, 2017Explorer
Awning Pulling Gutter Away from RV -- Best way to ReAttach?
This is on a TT, but the same problem could occur on any RV with awnings, so I am posting this under General RVing Issues.
In the pic below you can see the problem. The tension from the awning, which is attached to the rain gutter, has pulled the gutter + awning anchor away from the side of our RV.
With the awning in the fully retracted position, the tension it applies to the gutter is such that it requires much more effort to push the gutter back down against the RV wall than is required when the awning is extended out from the wall, as it is in the photo. This of course is the reason the problem has manifested.
What would be the best way to re-attach the gutter? Due to the outward pull of the awning anchor when the awning is retracted, reattaching it with caulk would not last long. I'm thinking to use some stainless steel screws plus some kind of caulk, but I don't have any idea what I would be screwing into. FYI, the TT is a 2011 Jayco 256RKS.
Does anyone have any experience repairing this problem in such a way that the repair will hold? Pic of problem below.
I am also thinking that once a repair is completed, that I will try to leave a tiny bit of slack in the awning when retracting it in future, to try to avoid the gutter being pulled away again.
