CA_Traveler
Apr 08, 2017Explorer III
Fosters wrote:Yup, check with the manufacturer. Probably don't want to over tighten.
thx rv2go, have not "been up there" to take a look yet n was not aware that it could be tightened or loosened for that manner. what kind of tool are we talking about to do so, assuming they are all standard?
update.....I just looked outside for a 2nd from the ground. all is see that can be adjusted is the open (female insert) end of a hexagon pipe like one would use an "allen wrench" of sort to turn it? but I'm not even sure that is supposed to turn? finally, I do see a dometic sticker on the underside of the awning so can/will contact them for instruction or tips as they are manufacturer.
For the Carefree SOK toppers you would extend the slide, rotate the top cover out of way, pin the roller, bring the slide in enough while keeping the fabric free, remove the roller and turn it, reinstall the roller, remove the pin, extend the slide, check and secure the cover.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
