Fosters's avatar
Fosters
AWNINGS above the Slide Outs during the Wind r KILLING ME!!!
I'm a full timer in my 5th. And for some reason, it is bloody windy allllll the time or around the seasons here in Jersey. Except for summer perhaps. So yes, I am able to pull in the main awning which is great. But on my 3 slides I have 3 awnings. And I leave my slides OUT 24/7 of course, so awnings stay out! They must stay out. These awnings cannot be retracted like the main awning.
Problem is, cannot take in those 3 awnings. And yes, I understand that they are designed that way to protect the top of the slide from branches, droppings, etc. For when it comes time to pull in the slide, it moves in easily and without obstruction.
But my problem (and surely I am not alone), is with the more then I can ask for bursts of winds come the air FLAPS N FLAPS UNDERNEATH THE AWNINGS AND MAKES LOUD N CONSTANT ANNOYING NOISE. And as I cannot retract those 3 awnings IN without closing the slides IN, what do I do? And who knows what the past fall n winter months damage must have been done? For these RV's are for built n designed for "recreational use" ONLY and not for full time living.
I was thinking about buying some heavy duty and thick (whatever the height is from the top of the slides to the awning) foam/sponge and cutting it into shape like a "wedge" of sort. And stuff inside that space so the air cannot channel inside and cause the "flapping" of the annoying sound!!!
Thanks in advance for your thoughts or suggestions!
  • My TT didn't come with them so I added them.
    One of the best things I did and would do it again.
    OP, on the rare event it happened to us (once in 12 years) we pulled the slide in about half way to stop it.
  • What is the purpose of those awnings?
    When I bought my 5th they were an option. No thanks I'll get up and sweep any twigs and leaves off before I close up.
  • Get some of those big foam Nerf ball things maybe 2 to 3 per slide just slide right in there that'll take up that extra tension
  • Take the awnings off. For the few times your going to pull the slideouts in, you can clear any sticks etc. the day before
  • Harbor Freight. Buy the 4 inch wide tow straps and a package of ratchet straps. That will tie them down during high winds.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
