Dutch_12078
Jun 27, 2015Explorer III
If you're referring to water leaking out of the city water connector when no hose is connected, then you need to determine why the built-in check valve is leaking. It might be just a bit of dirt in the valve or it might be an 0-ring out of place, or worst case the valve has failed completely, requiring replacement. Replacements are not expensive though, and the actual work is usually not very difficult.
