DrewE
Aug 15, 2016Explorer III
Some converters don't operate properly without a battery. It's very reasonable to assume that a bad battery could also cause improper operation or non-operation, depending on the battery fault.
Connecting most any known good 12V lead acid battery in temporarily would let you check the converter using a voltmeter. Even something as simple as connecting the trailer electrical system to the truck battery with jumper cables (carefully) should be sufficient to verify the converter output voltage.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
