RJsfishin
Aug 17, 2016Explorer
Sure, buy a new battery,...even if ya don't need one.
Common sense would tell me to start w/ checking the converter voltage.
If the converter is not up to spec, the new battery won't be new for long !
MEXICOWANDERER wrote:
The biggest fault of novice troubleshooting is folks try to start in the middle and work their way to both ends at the same time. 2nd biggest is to assume the problem always lies with the most complicated device.
The battery is bad? Damned if I know how you can outwit that. Start there. New battery. Then see what the symptoms are or are not...
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
