Purchased two GC-2 Interstates back in Sept. of 2013. For a couple months now, my charger (not the onboard converter/charger) has been telling me "bad battery", cannot charge. Thinking the charger is ...
An easy quick check would be to compare the voltage of the two batteries to each other. Since they've received the same charging and general treatment, they should both have pretty nearly the same voltage across them. A shorted cell, for instance, would make one significantly lower than the other.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
