dee74's avatar
dee74
Bad city connection check valve cause low water pressure?
To give you some background, I used my freshwater tank and pump recently and everything worked well. I rarely use the tank and pump and almost always,99.9% of the time, connected at the city water connection. I used my camper this weekend and was connected to city water and my water pressure was very low and kept dropping to a trickle. The pressure at the campground was freat and I do not use a pressure regulator, just a straight hose connection. I went and investigated and found the check valve seemed to be sitting crooked and possibly deformed. I straightened it out as much as I could without tools and the water pressure seemed a little better but still not great. I know a faulty valve can cause a leak when using the pump but could this valve be causing the low pressure when using the city water connection?
  • Was the water pressure still low when you checked your pump after the problem with city water?
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
