iagary's avatar
iagary
low pressure propane Tee - Quick Connect
My camper has a low pressure auxiliary propane hose with a female quick connect on the end. I have a campfire in a can and a weber q (converted to low pressure) that I can run off this aux hose. Does anyone know where I can find a low pressure "tee" with one male quick connect and two female quick connect fittings? I was certain I would go onto amazon and find it available from Camco but not so lucky. Another question - do you think my LP regulator on my TT would provide enough flow to run both these at the same time? If not I might as well just switch from one to the other.
Thanks for any help.
