A recent electrical issue made me hook up my tester to my rv outlets. They all test with the "bad ground" light. I think my trailer has always been like this. Everything in the camper works as it shou...
Your RV has the neutral and ground separated. It is not bonded even in the load center like a residence. The RV's 120 V system relies on the connection from your RV load center, through the cord, and to the power source, eventually having ground and neutral bonded in the power source's load center.
If all your receptacles show an unbonded ground connection, the most likely culprit is the cord. Check for continuity of the ground through the cord.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
