Jetstreamer
May 28, 2016Explorer
Bad ground?
A recent electrical issue made me hook up my tester to my rv outlets. They all test with the "bad ground" light. I think my trailer has always been like this. Everything in the camper works as it shou...
Right, should be zero to low millivolts depending on the load current in the neutral wire.
IMO, the bad pedestals probably had a bad ground, as in open and/or resistive path back to the point of supply bonding between the neutral and ground.
Second thought, could have been a high resistive neutral wire as well. If you were to take a VAC reading from the Ground to Earth at the pedestal we might then know which...........
