dougrainer wrote:
mrad wrote:
In my earlier post, some commented the Xantrex 1000 might be too small. After thinking about it, I know it worked for a few hours last October. When we got ot our campsite, they had put us in a 30 amp, so I had to run around town looking for an adaptor. When none was to be found, I bought a gas can and put gas in the onboard tank so I could use the generator to give the batteries a good charge when needed. The batteries seemed to make it through the night.
AS I stated earlier, a 1000 watt Inverter has more than twice the power to run a residential refer. BATTERIES and Capacity of Batteries is your limiting factor. You could have a 2500 watt Inverter and you would still have the same problem. Doug
FYI, most class A Oems will state no more than 24 hours running a residential refer with just 2 deep cycle batteries. You CAN run longer, but they state 24 hours.
That's good to know I would only need 8-10 hours of run time with my two golf cart batteries. I would like to add another pair, but I don't think I have the room
