mielock
Aug 23, 2014Explorer
I have solved the problem and before you judge me when I state it was only the 30A fuse, please read what happened. First, I have red LED lights next to each fuse which is supposed to glow red when a fuse blows. There was no lit LED light. Second, I measured 11.74 VDC when the problem was first discovered, and still measured this voltage today before troubleshooting. When I discovered there was nearly a volt difference between battery voltage and problem slide switch voltage, I started tracing the problem from the switch which led me to the fuse. So, the moral of the story is a blown fuse can still allow voltage to pass through and those red LED lights don't always work. Now I can only hope the fuse doesn't blow again and expose another problem to diagnosis, plus, I have no idea why my 15A control panel fuse blew twice. Thanks to those who responded with assistance
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
