knovak
Jul 02, 2013Explorer
Electric Slide Issues
We have a 2003 Starcraft TravelStar 21SSO. Bought is used at the end of last summer.
Our slide is not working. We were camping this past weekend in less than ideal conditions (rain and lots of mud, not electric other than the battery) and had the slide out. I hand cranked it out and hand cranked it back in. Only used the electric to make sure it was tight before we pulled out. It worked fine.
Today I went to load the camper and needed to put the slide out. Hit the slide button above the fridge and nothing. I hand cranked it back out.
Hubby came home. Fuse is fine. Used the test light (or whatever it is to check). Not getting juice at the switch. No juice at the motor under the couch. Then we find out that the lights in the slide above the table and couch are also not working.
Could it be moisture? We dealt with a lot of mud pulling out but did hose the camper off when we came home. Did we get too much mud under the camper?
Any ideas of where to start.
Thanks in advance.
Thanks in advance.
